James,
Thanks again for your help with the Zoom question. I have another question if you have a moment.
· I’m trying to get the correct syntax for PULLDATA to return an answer from my external_choices tab based on a selection that is also in the external_choices tab
· Example:
o User selects their State, say “GA”
o Based on that selection the list of Counties for Georgia appears and they can then select the appropriate County.
o In the Region and Chapter Notes which are the next two rows, I would like to use “pulldata” and return the correct chapter and region based on the county they selected.
· Currently I’m using select_one and it works fine but the user has to select the radio button, I want to eliminate the step of them tapping on the radion button next to the chapter and region returned.
Can you help with the correct syntax?
Greg
Greg Tune
Geospatial Technology
maps.redcross.org<http://maps.redcross.org/>
