Remove individual reponses from 321 Survey data table
612
05-10-2017 04:37 PM
ErnestDelemeester
I use arcGIS Online and created a 123Survey for my high school students to report water testing data.  There are three survey responses I'd like to delete.  Is there a way to remove individual reponses (identified as features) in the data table?
JamesTedrick
Esri Esteemed Contributor
Hi Ernest,
The easiest way would be to click the 'Open in ArcGIS Map Viewer' button on the Data tab in the Survey123 website.  This will open the survey data in a tool with editing control- click on the 'Edit' button to begin editing, then click on the points you want delete- there's a delete button at the bottom of the pop-up that will appear in the map.
