Editor and Templatepicker Creation in Custom Widget
3105
05-09-2017 01:33 PM
MargoBlosser1
I am creating a custom Widget that is added to a WAB Developer Edition application. I am adding the editor and template widget to a bodyPanel div.
My main widget – GeoCapture gets loaded through the config.json inclusion. The GeoCapture Widget loads a dropdown menu that allows a uses to select what they want to do – 1) Add New Feature 2) Select Existing Feature.
Depending on the menu pick a second widget is created that has the UI for either 1) Add New Feature 2) Select Existing Feature.
For the Add New Feature widget:
1) I create and startup the search widget
2)Create the editor and templatepicker widgets and start the widgets.
I do not get the templatepicker templates displayed after editor and templatepicker widgets have been created (see image).
In the debugging tools for the AddWidget around line 201, I can see that at “featureLayers: templateLayers,” I have layers.
I suspect that the issue is that the editor and template picker are not getting instantiated and are not running widget startup on the map onLoad event. I likely need to do something like this “this.map.on("Load", lang.hitch(this, 'editWidgetCreate'));” to my Add New Feature widget. But I am not sure how to hitch to a separate widget.
Thanks in advance for any suggestions!
-Margo
ScottLehto2
I was wondering/fighting something similar, but you are far ahead of me. Newbie question. How did you know how to create a panel div where you could bring the editor and template picker div's in? I was looking to do something similar and i'm just getting started. Any suggestions or references would be very helpful.
RobertScheitlin__GISP
Margo,
   The map is long since loaded once your widget is created so you will never get a map.on load event fired inside your widget.
MargoBlosser1
Scott,
Make a templated widget and load your UI. Look at  'dojo/text!./widget.html','dojo/text!./themes/uiAdd.html','dojo/text!./themes/uiSelect.html', in the require statement. Think of the widget.html as the main html. I then load the different UIs when I load the widgets that I want.
I had to load the editor template during the map load event to get it to work.
I was hopping to be able to hitch the map load event to the Add widget scope but not sure how to do it so I created work around and loadded editor widget during map load event and swap out UIs from view created during load.
here is a snippet of my Widget UI
<div id="MenuNode" data-dojo-attach-point="MenutNode">
<div class="headerPanel">
<table>
<tr width="300px">
<td style="padding:10px;">
<font color="white">Step 1. Select Input Method</font>
</tr>
</table>
<div>
</div>
</div>
<div class="bodyPanel" style="height:auto">
<table align="center" style="padding:10px;">
<tr>
<td style="padding:5px;">
<select data-dojo-type="dijit/form/FilteringSelect" id="fruit" name="fruit" style="" data-dojo-attach-event="onChange:uiSelector">
<option value="Add">Add New Feature</option>
<option value="Select">Select Existing Feature</option>
<option value="Update">Update Features</option>
</select>
</td>
<td></td>
</tr>
</table>
</div>
Hope this helps!
-Margo
ScottLehto2
Thank you. This will help. A couple more newb questions if you don't mind. In the JavaScript file you reference the
domConstruct.empty(this.ResultsNode); is this a node that is created by this line of code or is this referring to an HTML element declared in your widget.html file?
And when you say your main widget – "GeoCapture gets loaded through the config.json inclusion.", How can one get information on that?lol.
