Esearch Widget's Export to CSV is empty when Add Result as Operational Layer is not checked
1039
05-09-2017 08:49 AM
jonathanrobinson
Hello Robert Scheitlin, GISP‌, we are using the esearch widget and noticed the export to csv produces an empty table when add results as operational layer is not checked.  Is this expected behavior?
RobertScheitlin__GISP
Jonathan,
   That issue was fixed a while back so you must be using an older version of WAB and the eSearch. If you update to 2.4 you will not experience that issue.
Jonathan,
jonathanrobinson
Ok, thanks!
