Survey123 Connect - API url in disconnected environment
2069
05-08-2017 08:58 PM
AngusHooper
When signing into Survey123 Connect via a Portal named user, you are prompted to provide an API url. Is it possible to host the API internally and expose this to the client? The environment is in a disconnected state and has no internet access. I have seen mention of this some years ago but cannot source any recent documentation or mention of this functionality.
Cheers
JamesTedrick
Esri Esteemed Contributor
Hi Angus,
Currently, the Survey123 API is not available for an on-premises installation.  As it happens, we are actively working on this and would be happy to follow up with you or your customers if they are interested in beta-testing this functionality.
AngusHooper
Thank you, emailed
VentsislavStanchev
hello,
how we can join beta testing for Survey123 API for an on-premises installation, or already is available?
JamesTedrick
Hi Ventisislav,
We had to step back from the deployment that was under development at the time of this thread.  We are beginning to document a new deployment process and will be posting it into Survey123's Esri Early Adopter Community when ready for testing (which will probably be a bit after the Developer's Summit).
