Numbers data missing from upload
2067
05-03-2017 12:44 PM
EddyClark
I noticed missing data from some of our inspections and was able to recreate the problem.  The problem is when you use the appearance 'numbers' for an integer field.  Not sure if this applies to decimals, but probably.  When you enter a value into a field using the number pad and then move on to the next - if the number pad does not close and the cursor continues to blink then the data will not get uploaded.
IsmaelChivite
Esri Notable Contributor
JamesTedrick
Esri Esteemed Contributor
Hi Eddy,
I've been able to replicate the behavior you're describing.  I'll file an issue to address it.
IsmaelChivite
