Update fields dropdown when layers dropdown is changed
2586
05-02-2017 10:12 AM
RoySP
Newbie question here.
I have a LayerChooserFromMapWithDropbox added to my widget.
I am trying to make the "selection-change" event to work so that when a layer is changed, a dijit/form/Select box gets updated with fields from the selected layer.
This should be pretty simple but my limited experience is making this take longer than it should.
This is what I have so far...
      postCreate: function() {
        this.inherited(arguments);
        var layerChooser = new LayerChooserFromMap({
          createMapResponse: this.map.webMapResponse
        _layerChooserDropBox = new LayerChooserFromMapWithDropbox({
          layerChooser:layerChooser
        }, this.layerChooserDropBoxDiv);
        on(_layerChooserDropBox, "selection-change", lang.hitch(this, function(){
          if (_layerChooserDropBox.getSelectedItem()){
            _layerObject = _layerChooserDropBox.getSelectedItem().layerInfo.layerObject;
            array.forEach(_layerObject.fields, lang.hitch(this, function(fldObj){
              // update fieldSelectDiv
RobertScheitlin__GISP
Roy,
  Something like this then:
            //Clear old values first
            var i;
            for (i = this.fieldSelectDiv.options.length - 1; i >= 0; i--) {
               this.fieldSelectDiv.remove(i);
              var option = domConstruct.create("option");
              option.text = fldObj.name;
              this.fieldSelectDiv.add(option);
Roy,
            var i;
RoySP
Perfect Robert! Thank you!
