Kernel Density Workflows and Use Cases
2734
05-01-2017 12:11 PM
TimothyHales
Esri Notable Contributor
How are you using Kernel Density? I'd like to understand your workflows and use cases. Are you using the output raster only as a visual, or are you processing it further using a tool like Zonal Statistics? Thanks for your input!
DanPatterson_Retired
If I am working with points in that context, I prefer to use a Voronoi diagram or Delaunay triangulation since I can choose how to symbolize or interpret the intervening space between points.  Probably not what you are after, but I find density and interpolation representations of space a bit disconcerting in that the original point patterns are not retained and presented by default.  They may look nice, but are they representative.
NeilAyres
Forever the scientist
Sometimes, a nice picture is all that is required....
I have used kernel densities quite a lot in the past, but you have to be careful about search radii and output cell sizes to be able to interpret the output correctly.
Neil...
....but you have to be careful about search radii and output cell sizes...
you mean all the stuff that everyone ignores or has no clue about
TimothyHales
Also don't for get about the symbology classification methods as well.
