Arcpy Batch ExportToJPEG & OverwriteOutput Not Working
2611
04-26-2017 09:19 AM
JudsonCrouch
Hello All,
I am working on a script to batch export a list of user selected MXD's to either JPEG, PDF, or JPEG & PDF using arcpy.mapping.exportToJPEG. I give the user the option to overwrite existing images in the selected output location however the JPEG's will not overwrite while the PDF's will.
Does anyone know why this might happen? I have researched it a bit and am unable to find a solution.
import arcpy as ap
import os
docs = ap.GetParameterAsText(0)
exportPath = ap.GetParameterAsText(1)
imgRes = ap.GetParameterAsText(2)
imgJPEG = ap.GetParameterAsText(3)     #Boolean
imgPDF = ap.GetParameterAsText(4)     #Boolean
overwrite = ap.GetParameterAsText(5)     #Boolean
def transmit(message):
     ap.AddMessage(message)
     return
def exportGraphics(docs, exportPath, imgRes, imgJPEG, imgPDF, overwrite):
     if str(overwrite) == 'true':
          ap.env.overwriteOutput = True
     for doc in docs.split(';'):
          mxdname = os.path.basename(doc)
          mxdname = mxdname.split('.mxd')[0]
          mxd = ap.mapping.MapDocument(doc)
          if str(imgJPEG) == 'true':
               jpg = os.path.join(exportPath,mxdname) + '.jpg'
               ap.mapping.ExportToJPEG(mxd, jpg, resolution = imgRes)
               transmit(mxdname + '.jpg Has Exported!')
          if str(imgPDF) == 'true':
               pdf = os.path.join(exportPath,mxdname) + '.pdf'
               ap.mapping.ExportToPDF(mxd,pdf, resolution = imgRes)
               transmit(mxdname + '.pdf Has Exported!')
          del mxd
if __name__ == '__main__':
Thanks in advance!
Judson
MitchHolley1
What's the error you get?
JudsonCrouch
It does not return any error when I run the script. It just does not overwrite the JPEG files but while overwrite the PDF files when exporting.
DanPatterson_Retired
I don't know what 'overwrite' is returning in terms of string format, but if you are going to test strings, you need to check the possibility that the case of the string is incorrect
test = 'True'  # or 'TRUE', etcetera
str(test) == 'true'
False
str(test).lower() == 'true'
True
JudsonCrouch
The str(overwrite) == 'true' returns a checkbox being checked in the script interface. The boolean parameter returns 'true' in lower case when the box is checked.
