Xamarin: Handling graphic click events
1820
04-25-2017 06:39 PM
brianbullas
I want to be able to run some code when a graphic or feature is clicked on.
On the mapview, I can see a tap handler(OnGeoViewDoubleTapped and OnGeoViewTapped), but it returns the MapView and a point in the event.
I can't find in the FeatureTable or the GraphicsOverlay a way to handle a click event...IE run some code when a Feature or Graphic is clicked on.
The only solution i can see is to use the GeoViewInputEventArgs e, find the point they clicked on, then do a query to see what they clicked on.
Is anyone able to tell me how to properly handle a click event on a feature or graphic?
brianbullas
OK, I found the following in the samples. It's mostly doing what i thought....
var tolerance = 10d; // Use larger tolerance for touch
             var maximumResults = 1; // Only return one graphic
             var onlyReturnPopups = false; // Don't return only popups
             // Use the following method to identify graphics in a specific graphics overlay
             IdentifyGraphicsOverlayResult identifyResults = await TreeMapView.IdentifyGraphicsOverlayAsync(
                 _workingLayer,
                 e.Position,
                 tolerance,
                 onlyReturnPopups,
                 maximumResults);
             // Check if we got results
             if (identifyResults.Graphics.Count > 0)
                 // Make sure that the UI changes are done in the UI thread
                 Device.BeginInvokeOnMainThread(async () => {
                     await DisplayAlert("", "Tapped on graphic", "OK");
brianbullas
                 _workingLayer,
                 e.Position,
                 tolerance,
                 onlyReturnPopups,
                 maximumResults);
