Using field values to update a field using a search and update cursor
2290
04-12-2017 12:46 PM
TessOldemeyer
I am trying to update a field using the arcpy.da.Update cursor where I can use two field values from a select by location result to populate a new field. It seems like a spatial join route may be the best approach here. With this code, I am now receiving an error of 'tuple' object has no attribute 'GEN_UNITS' for the 'result = joinsubrow.GEN_UNITS/joinsubrow.LINES' line. Do I need to search out these field values separately in separate search cursors? What would be the best route here? Thanks in advance!
   import arcpy
   from arcpy import env
   arcpy.env.OverwriteOutput = True
   defaultGdbPath = 'C:\Topo_Check_Tess_V5.gdb'
   subLayer='C:\Topo_Check_Tess_V5.gdb\Subs'
   transLayer='C:\Topo_Check_Tess_V5.gdb\TLines'
   ppLayer='C:\Topo_Check_Tess_V5.gdb\PPs'
   arcpy.AddField_management(subLayer, "GU_Count", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
   GUCountField = "GU_Count"
   #Make feature layer
   arcpy.MakeFeatureLayer_management(ppLayer, "ppLayerGU")
   #Make feature layer
   arcpy.MakeFeatureLayer_management(transLayer, "transLayerGU")
   pp_trans_GUJoin ='C:\Topo_Check_Tess_V5.gdb\pp_trans_GU_SpatialJoin'
   SubLayer_pp_trans_GUJoin ='C:\Topo_Check_Tess_V5.gdb\SubLayer_pp_trans_GUSpatialJoin'
   #spatial join of feature layers
   arcpy.SpatialJoin_analysis ("transLayerGU", "ppLayerGU", pp_trans_GUJoin,'JOIN_ONE_TO_ONE', 'KEEP_ALL', '#', 'WITHIN_A_DISTANCE', .000002)
   #Make feature layer
   arcpy.MakeFeatureLayer_management(subLayer, "SubLayer_Layer")
   arcpy.SpatialJoin_analysis ("SubLayer_Layer", "ppLayerGU", SubLayer_pp_trans_GUJoin, 'JOIN_ONE_TO_ONE', 'KEEP_ALL', '#','WITHIN_A_DISTANCE', .000002)
   #Make feature layer
   arcpy.MakeFeatureLayer_management(SubLayer_pp_trans_GUJoin, "JoinLayer")
   LINE_Fields = ['LINES','GEN_UNITS']
   with arcpy.da.UpdateCursor (subLayer, [GUCountField, "SHAPE@"]) as GUCalcCursor:
      for subrow in GUCalcCursor:
         arcpy.SelectLayerByLocation_management("JoinLayer",'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
         with arcpy.da.SearchCursor("JoinLayer", LINE_Fields) as JoinLayerCursor:
            for joinsubrow in JoinLayerCursor:
      subrow[0] = result
      GUCountField.updateRow(subrow)
JoshuaBixby
MVP Esteemed Contributor
You are mixing the syntax for working with the older/original cursors and the newer Data Access cursors.  The following line isn't valid:
The DA search cursor returns a tuple containing values for the fields specified in the cursor, not a row object like the original search cursor.
What happens when you change the line to:
result = joinsubrow[1] / joinsubrow[0]
TessOldemeyer
Thanks! That was definitely a huge part of the problem. I have attached the newest rendition. It is still probably full of quirks, but seems to be getting somewhere. It is currently getting stuck on line 66 with an AttributeError: 'str' object has no attribute 'updateRow'.
import arcpy
ppLayer='C:\Topo_Check_Tess_V5.gdb\PP'
#Make feature layer
#Make feature layer
SubLayer_pp_trans_GUJoin = 'C:\Topo_Check_Tess_V5.gdb\SubLayer_pp_trans_GUSpatialJoin'
arcpy.SpatialJoin_analysis ("transLayerGU", "ppLayerGU", pp_trans_GUJoin, 'JOIN_ONE_TO_ONE', 'KEEP_ALL', '#', 'WITHIN_A_DISTANCE', .000002)
#Make feature layer
arcpy.SpatialJoin_analysis ("SubLayer_Layer", "ppLayerGU", SubLayer_pp_trans_GUJoin, 'JOIN_ONE_TO_ONE', 'KEEP_ALL', '#', 'WITHIN_A_DISTANCE', .000002)
#Make feature layer
        arcpy.SelectLayerByLocation_management("JoinLayer", 'WITHIN_A_DISTANCE', subrow[1], .000002, "NEW_SELECTION")
        if int(arcpy.GetCount_management(in_rows="JoinLayer").getOutput(0))==1:
            with arcpy.da.SearchCursor("JoinLayer",['LINES','GEN_UNITS']) as JoinLayerCursor:
                        GEN_UNITS = joinsubrow[1]
                        LINES = joinsubrow[0]
                print GEN_UNITS
                print LINES
                if joinsubrow[1] > 0:
                    result = GEN_UNITS/LINES
                else:
                    result = 0
                print result
                subrow[0] = result
DarrenWiens2
Also, once you get to it, the final line should be:
GUCalcCursor.updateRow(subrow)
TessOldemeyer
Thanks! Just saw this! Looks like that worked.
