Identify feature classes in network
1426
04-02-2017 10:37 PM
ModyBuchbinder
Hi all
I need to scan a big directory of files and project all the feature classes that I find.
Some feature classes are part of network (or topology) and cannot be projected.
I could not find any way to find it using Describe. The featureType is Simple.
Maybe ListDataset to find network then try to understand what layers are in this network?
Mody
DanPatterson_Retired
... network-dataset-properties ... and ... network-attributes ... and others can be found if you expand the whole Describe help tree but presumably none of these fit the bill
ModyBuchbinder
I was thinking to check if the describe object has any of these properties but they will exists only if I describe the network itself and not any of the layers in it.
looks like that is the design
