Python Loop Addition
3121
5
03-31-2017 12:59 PM
MatthewDriscoll
I am using a search cursor to get some values.  After I would like to add the next total to the total of all the results before it in order.  Not sure what to do, iterate, range, re-loop?
Example:
[a,b,c] would result in [a, a+b, a+b+c]
[3,5,2,3] would result in [3, 8, 10, 13]
value = ""
with arcpy.da.SearchCursor("Feature", "Field") as curs:
 for row in curs:
 value = row[0]
Use the values in "value" to do what I want.
The script will run in ArcGIS Pro.
DarrenWiens2
Use the += operator to accumulate values:
>>> input_list = [3,5,2,3]
... output_list = []
... value = 0
... for i in my_list: # do similar inside your cursor
...     value += i # same as value = value + i
...     output_list.append(value)
... print output_list
[3, 8, 10, 13]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DarrenWiens2
... value = 0
MatthewDriscoll
Thank you!  I was getting tripped up by my simple mistake of using value = " " instead of value = 0.
DanPatterson_Retired
If you are scripting an doing a lot of math, invest some time in learning numpy, a lot of these calculations are builtin
>>> import numpy as np
>>> np.cumsum(input_list).tolist()
[3, 8, 10, 13]
JoshuaBixby
MVP Esteemed Contributor
Where are you storing the results, in the table the search cursor is iterating over?  If so, you could use an update cursor and do it in place.
Looking just at cumulative totals, the previous responses are all good.  One other option that splits the difference between rolling your own loop and using a 3rd-party library is the accumulate function in itertools (only work in Pro).
>>> from itertools import accumulate
>>> list(accumulate(input_list))
[3, 8, 10, 13]
Then someone will want the cumulative sum returned so they can calculate proportions  besides numpy and scipy are builtins in Pro distributions anyway
>>> a = [3,5,2,3]
>>> s = np.sum(a)
>>> cs = np.cumsum(a)
>>> cstand = cs/s
>>> cstand
array([ 0.23076923,  0.61538462,  0.76923077,  1.        ])
or just plain old slicing... but you will need to use a def if you really want to fill values into a table one record at a time.... enough for code golf
[sum(a[:i] ) for i in range( 1, len(a)+1 )]
