.ecd files are not created when tools run successfully
1909
5
03-30-2017 01:44 PM
GalinaLilova
All Train Classifier tools in Segmentation and Classification toolbox shows ecd files was successfully created when I used them. When I went to output data folder, file is not there. What could be the problem?
Tags (1)
DanPatterson_Retired
did you search .ecd using windows file explorer, just to make sure that they didn't go astray
GalinaLilova
Yes, I did . Only Train Iso Cluster tools produces ecd file in a location I indicated.
MLC , SVM and Random Trees  are not producing any ecd file even though I get green check after running the tool. I checked many folders under appdata rooming esri , but cant find them.
Ok, at least one did... I would have to check the others to see their requirements.  You might too since I don't know what your rasters are
GalinaLilova
I am using a PCA tool result of  3 bands 8 bit depth image. I dont think the problem stems from the raster file.
