See Datasets and Relationships without granting permissions?
1665
5
12-29-2010 09:35 AM
JerryGarcia
Occasional Contributor II
Using SQL Server, I set-up a user and connected via ArcSDE.  The user can see all datasets and relationship classes, but no data.  I have not granted any permissions yet.
Given I have not granted any permissions to database objects yet, why can the user see the datasets and relationships?
Did I set something up wrong with the user?
I do not want the user to see anything until I grant read access.
Any help would be very much appreciated!
VinceAngelo
Esri Esteemed Contributor
Feature Datasets and Relationships are not RDBMS objects which can have access
defined (just rows in SDE-owned tables).  The actual tables ("feature classes") can
have GRANTs applied, so the contents of the meta-objects can be restricted to
specific users (if you look inside a FDS as an unprivileged user, it will be empty).
- V
JerryGarcia
- V
Is there a way to hide feature datasets and relationships from users when they connect to the ArcSDE database?  This is a security issue whereby users should not know these feature datasets exist unless they have access to the feature dataset's objects.  There names give away too much information.  Thanks.
VinceAngelo
I don't think so. This has been discussed extensively in the past (search forums.esri.com).
It comes down to a design constraint -- If Desktop had to check for the existance of every
table referenced by any FDS before the initial "open" returned data, some sites would be
taking 30+ minute coffee breaks upon initial connect.
Your only options are to either forgo FDS membership (i.e., you're using it as a container,
not to edit related tables with shared topology) or to be less explicit in your FDS naming
scheme.
- V
JerryGarcia
scheme.
- V
Thanks for your comments.  We could do away with FDS, but relationships would be hard.  Even if we rename the relationship classes to something non-descriptive, the error message when a user clicks on the relationship displays the name of the feature class which the user does not have access to.  We do not want folks to see this.  As a work-around, we could drop all GDB relationship classes, and have an ArcMap tool which builds these on-the-fly as ArcMap document relationships for the feature classes in the document?  Not optimal, but may work?
VinceAngelo
I'd suggest you file a bug on the information bleed for the relationship class.
A more generic message would be more appropriate.
- V
