Draw/eDraw widget tool tip on map hover
1796
03-10-2017 01:09 PM
JohnWolynec
Does anyone know how to change the default text that appears after selecting a geometry from the draw tool, and then hovering the pointer over the map?
It seems like the text is set based on the geotype/measureType selected, I am just not sure where the text is populated.
RobertScheitlin__GISP
John,
   Those tooltips like "Click to add point" comes from the JS API. To change those you just set the text using code like this:
require(["dojo/i18n!myApp/nls/jsapi"], function(bundle){
  bundle.toolbars.draw.addPoint = "blah blah";
