Error loading Map Journal
1797
03-08-2017 09:41 AM
FormulaScienzaNews
I am trying to load my App, but I get the message: Something went wrong, the Map Journal did not load correctly. Have you please some suggestion?
URL: http://www.arcgis.com/apps/MapJournal/index.html?appid=0462439623b643f0be6419a1c75ea53f
RupertEssinger
Esri Alum
Hi, Sorry about the issue.
The first thing to try is to sign-in to My Stories on the Story Maps website: and then click on the entry for this story to expand it (or click the Check Stories button to check all your stories at once). That will check this story for issues and it will give messages if it finds issues such as if an ArcGIS Online web map that is displayed in the story has been deleted or unshared or is not loading for some reason, or if an image used in the story can't be found.
Note that My Stories doesn't check for whether ArcGIS Online web scenes referenced from a story map are missing, unshared or broken, so if the Map Journal contains any 3D content, be sure to check each scene to see if can be accessed.
Rupert
RupertEssinger
Esri Alum
Rupert
