config
windows 10, pro 1.5
pro 1.4 -> 1.5 update or reinstall
An product check list non-enable error has occurred since loading the license server from the License Server.
Cause registry not writing for installing.
Solution to.
The error was put through through regedit.
Additional items are shown below.
Current Path
HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Licensing
Change value
"SEAT_PREFERENCE"="Float"
"SOFTWARE_TYPE"="CLASSIC"
Add Key
"AUTHORIZATION_TYPE"=""
"LOCK_AUTH_SETTINGS"=""
Add Key and Value(When using a extantion)
"Spatial Analyst Pro"=dword:00000001
"3D Analyst Pro"=dword:00000001
in Pro 2.1 for extensions add the key/value pairs under
HKEY_CURRENT_USER\Software\ESRI\ArcGISPro\Licensing\Extensions
I still can't figure out a way to enable this in the GUI
I've tried setting the LOCK_AUTH_SETTINGS to False and "" - neither worked
