Calculating using decimals
2212
02-20-2017 05:06 PM
JohnPlunkett
Hi there
Working with a customer we sometimes need to do a calculation for example
pow((${BasalDiameter} *50),.42)*.66
However this fails when we view in Survey123 Connect
- Changing the calculation so that there is a leading Zero it works as expected. - Is this a known issue?
pow((${BasalDiameter} *50),.042)*0.66
Edit- using Survey123 Connect 1.10.43 Windows 10
JohnPlunkett
Hi Dan
Thanks for your response - unfortunately using spaces doesn't work - it appears that you need to have preceding 0's to make it work
DanPatterson_Retired
what about spaces... pow((${BasalDiameter} * 50), .42) * .66
I would use preceding 0's and spaces around operands in any case
JohnPlunkett
Hi Dan
some 'languages' are more fussy than others I suspect
MitchellProctor
Hi John,
I see you've already figured this out, but yes, leading zeroes are needed to make decimal calculations work, and this is expected behavior.
