Onscreen widgets - keep it open
3839
8
02-16-2017 06:19 PM
GisGKAuckland
Am new to WAB customization.
When I click the onscreen widget, only one remains open. I would one of them to remain open all the time. Any idea how it can be done?
RobertScheitlin__GISP
When using the launchpad theme if you add widgets to the AnchorBar controller instead of the on screen widget place holders then you can have as many open as you wish.
Short of using those two themes than you would have to modify the OnScreenWidgetIcon.js to comment out the code that closes all other open on screen widget:
    switchToOpen: function(){
      this.state = 'opened';
      // this.panelManager.closeAllPanelsInGroup(this.widgetConfig.gid);
      // array.forEach(this.widgetManager.getOnScreenOffPanelWidgets(), function(widget){
      //   if(widget.closeable){
      //     this.widgetManager.closeWidget(widget);
      // }, this);‍‍‍‍‍‍‍‍‍
If you use the launchpad theme or box theme then you can have multiple widgets open at once.
GisGKAuckland
Thanks for the reply
The Launchpad theme is the one currently used and from current indications people are not flexible to move to another theme.
I agree if the widget is put in the Box controller or the widget pool (as referred in the config), they remain open. This widget remain outside the Box Controller . These widgets behave like the minimize, maximize & home button in the left top.
One can put a basemap or About widget outside Box Controller and check the behavior. Only one is allowed open at one time. I can share a video if I am still not clear
GisGKAuckland
Guess this is what I was after
Glad to help.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
GisGKAuckland
Thanks Robert. That worked like a charm.
Also is this the correct forum to put questions like this for customization? The recent activity thread makes me feel nothing much is happening
This space is fine and the Web AppBuilder Custom Widgets space for custom widget development questions.
MichaelDeliberato
GisGK Auckland‌ is it possible to make the widget unable to be minimized or closed? we have a piece of text that we want onscreen no matter what. is that possible?
