Read from config file
1779
02-15-2017 08:46 AM
LefterisKoumis
I am trying to modify the script below to capture only a specific layer from the config file, let's the first one (index:0).
So instead of:
this.layerListView = new LayerListView({
layers: this.config.layers
}).placeAt(this.layerListBody);
I use
layers: this.config.layers[0]
But the "layers" does not store anything.
The first one will store all layers.
Suggestions?
Thank you.
RobertScheitlin__GISP
Ah. The AddLayer Widget that is helpful information. The LayerListView in that widget is expecting an array for the layers property, not just a single layer. you you need to create a new array with just the layer you want inside it then.
Lefteris,
   What version of WAB LayerList widget are you working with? The LayerListView contructor does not have a layers property.
LefterisKoumis
I am using v. 2.3.
I am trying to modify the AddLayer Widget  widget so it includes only layers that meet certain criteria.
like below. If you use  layers: this.config.layer it works but it captures all layers.
array.forEach(this.config.layers, function (layer) {
   layer.isSelected = false;
   if (layer.name === "climate"){
      layers: this.config.layer[0]
}, this);
Thanks.
LefterisKoumis
Got it. Thanks.
