arcpy PolygonToRaster ERROR 000918: Cannot retrieve feature class extent
3661
02-10-2017 06:23 AM
IsaacBoates
I am trying to convert a polygon feature class (created intermediately as part of a larger process) to a raster, which will have the same snap settings and cell size as another input raster. However, every time i try to run it, I get this error:
ExecuteError: ERROR 000918: Cannot retrieve feature class extent.
I cannot find any help on this issue and I don't know what to do. I have already seen this question and it did not help resolve the issue.
This is the code:
cell_size = float(GetRasterProperties(in_raster, 'CELLSIZEX').getOutput(0))  env.snapRaster = in_raster  PolygonToRaster(buffer_fc, z_field_name, stamp_raster, cellsize=cell_size)  return None
The same parameters work when I execute "Polygon To Raster" diretly from the ArcToolbox GUI.
IsaacBoates
The formatting broke the code.
This is it:
IanMurray
Honored Contributor
Here is the ESRI help for that error code:  http://pro.arcgis.com/en/pro-app/tool-reference/tool-errors-and-warnings/001001-010000/tool-errors-a...
From the help on the error code, I'd guess there is still a lock on the intermediate data after it is created, you mind posting code from where the intermediate data is created to where you run the Polygon to Raster?
Also for code formatting on GeoNet https://community.esri.com/blogs/dan_patterson/2016/08/14/script-formatting
IsaacBoates
Hi Ian,
Someone on stackexchange GIS also suggested a schema lock issue, which turned out to be true.  I thought at first it was a problem with a da.UpdateCursor, but I used a with statement, so it should be releasing the locks.  Doing a del statement on the row and the cursor still didn't help.  In the end I was able to fix it by quickly copying the features to a new feature class and deleting it after.  Not optimal, but it works.  I think that there is some kind of schema lock applied by MultipleRingBuffer() that isn't releasing properly.  I found an old question on stackexchange that described a similar issue but it inexplicably stopped happening for them so there was no real insight to be gleaned from it.
SteveLynch
Please try the following:
- use CopyFeatures to create of copy of the polygon feature class
- use this copy in PolygonToRaster
and which version of ArcGIS are you using?
-Steve
