How to open mmpk file in Android app
2309
02-10-2017 03:47 AM
KamalMittal
I am trying to open a .mmpk file (Mobile map package file ) in my app but not getting any result .(Black blank screen appearing).
Sample code provided by ArcGis for Open Mobile Map Package  were also not working.
Please provide me solution.
AlexanderNohe1
Honored Contributor
What sample were you using to open the mobile map package?
Do you have any sample code that you are willing to share?
KamalMittal
Hi Alexander,
Below is the link of code from Github which I am using. In this code, there is a function loadMobileMapPackage.
arcgis-runtime-samples-android/MainActivity.java at master · Esri/ArcGIS-runtime-samples-android · G...
I am getting an error inside addDoneLoadingListener method.
AlexanderNohe1
Honored Contributor
Do you have a link to the MMPK that you are trying to load?  It is already downloaded on the device?
Do you get anything in Log cat upon firing this method?
KamalMittal
Yes, I have put MMPK file on the device.
In Log cat, I am getting only "Failed to Load" error.
Can you please check sample code at your end as I am also not able to run sample code of MMPK file. I have doesn't change anything in the code.
