datetime
782
12-22-2010 04:30 PM
TedCronin
Any issues encountered with datetime with the addition of SP1 for ArcGIS 10?  It was working correctly at 10 and from the command line it is still working correctly, but from Wing I am not seeing the expected results.
At the command line:
>>>print datetime.datetime.now()
2010-12-22 18:22:24.496000
Python Shell in Wing:
2010-12-22 18:24:20.574000
Wing IDE Pro:
import datetime
433000
Python Window in ArcMap:
>>> import datetime
2010-12-22 18:29:02.105000
Any ideas?
TedCronin
Weird.
So, it seems like 3.2.12 fixed the issue. Another issue encountered with 3.2.9 after the SP1 install was that setting the path to a workspace, ie ENV.workspace = r"Database Connections\TestServer.sde"
then running
fcs = arcpy.ListFeatureClasses()
try:
     for fc in fcs:
     print fc
except:
     print arcpy.GetMessages(2)
was not printing the full path of the fc.
It was printing aspect_c16, when it should have been printing datebase.Owner.aspect_c16. This was fixed at 3.2.12 as well.
So, it appears that SP1 DID NOT fix the bug with Rasters where they are showing up when print feature classes is called, since aspect_c16 is a Raster.
