Issues in layer list
1082
02-04-2017 01:54 AM
SergeLespagnard
I have small issues with ArcGIS Earth v1.4 build 1586. When I rename the root node "My Data" in the layer list, it works fine and I can see the change in the json file, but when I reload the workspace next time the change is gone and the root node is back to "My Data".
Also, when I tick / untick some nodes before saving the workspace, I also can see the changes in the json file (isVisible=true / false") but at next reloading it does not recall my choices and everything is ticked back again.
Regards,
Serge
Tags (1)
XuewenZhang
Hi Serge,
Thanks for your comment. We will check this issue and will fix it.
Xuewen
Mandy_Li
Hi Serge, I assume you are using the shortcut key to rename 'My Data' node since there is no such option on the right-clicking menu. By default, the app will work consistently with what are defined in the workspace files, including folder name, layer visibility, etc. We will log this issue and check it later. Thanks!
SergeLespagnard
Yes I have renamed the root node using F2 shortcut.
