Populate EXIF data in images based on field inputs.
1141
02-06-2017 09:59 AM
TL2
I see in International Day against Nuclear Tests (1.7) release the functionality to add Lat/Long data to images was fixed/added.
Is there away to populate additional data to the images EXIF metadata  based on field inputs (Location Description, Comments)?  I see that GPS data and Date are included.
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Tucker,
Currently there isn't a way to populate additional EXIF fields with information from the form.
TL2
Can we use the pull data function to extract the EXIF geopoint data and populate fields?
JamesTedrick
The pulldata function doesn't work with the photo's EXIF stored location; you can extract location from photos afterward with ArcGIS Desktop tools - GeoTagged Photos To Points—Help | ArcGIS Desktop
