Editing Issue/Error for Adjacent Features
2666
02-03-2017 09:58 AM
SeanO_Brien
I'm working in Pro 1.4, and I'm trying to edit a polygon feature. I'm taking the original polygon, and doing a copy/paste to duplicate the feature and move the identical geometry to a different location (for a strip map index). However after the initial paste and moving of the feature, if I try to move/rotate/scale or just modify the feature in any way it does the same to any adjacent features (that touch) in the dataset even though I only have one feature selected (see attachments). Is there something I'm doing wrong?
AdamZiegler1
Hi Sean - At ArcGIS Pro I believe Map Topology is on by default. In the Edit ribbon click on the Topology drop-down and select 'No Topology.'
-Adam Z
AdamZiegler1
-Adam Z
SeanO_Brien
That worked. Thank you!
