Add trailing zeros to field
2543
6
02-01-2017 09:21 AM
CCWeedcontrol
I have a table BuildingTable with building info. There is a field called "Build_num" with characters like B37828 or B2898101 or R29499010C or R29499010C2 that i need to join to a shapefile but the the Shapefile BuildNum has a max of 11 characters like so B3782800000 or B2898101000. so i can't join the table to shapefile.
How can update the BuildingTable field "Build_num" to add trailing zeros to that field?
I tried the following, i added a new filed to insert the new Build numbers with the trailing zeros but nothing happened.
import arcpy
fc = "BluidingPermitsTable"
fields = ('Build_num', 'BuildNum')
with arcpy.da.UpdateCursor(fc, fields) as cursor:
    for row in cursor:
        if row[0] <= 11:
            row[1] = '0' + str(row[0])
            cursor.updateRow(row)
Thanks.
RandyBurton
To add trailing zeros, try something like:
BuildNum = "B37828"
print BuildNum.ljust(11,'0')
print "B2898101".ljust(11,'0')
# for your code
row[1] = row[0].ljust(11,'0')
RandyBurton
BuildNum = "B37828"
# for your code
DanPatterson_Retired
Or for current and future versions of python.
"{!s:0<11}".format(BuildNum)
'B3782800000'
RandyBurton
Knew there had to be a way using .format.  Thanks Dan_Patterson
It is being replaced with....  f"stuff formating{}" ... to simplify having to do "stuff formatting {}".format.  It is now in la familigia with s", r" and a" formatting.  Came out in python 3.6.  ArcMap-athians aren't going to see it for a while and Pro is still on 3.4
FYI Overview — Python 3.6.0 documentation  and 3.7 Dev is there for sneak preview for those that want to pre-book
BlakeTerhune
MVP Frequent Contributor
ArcMap-athians
CCWeedcontrol
Thanks to both of you, both options worked great.
