Show legend in Layer List widget by default
10490
14
01-31-2017 11:52 AM
AndrewL
I would like the Layer List to display the legend by default (instead of clicking on the layer for the dropdown legend to appear).
I tried editing the following code in LayerListView.js where I added the "unfold" text, but all that does is update the triangle orientation like the screenshot below. Thank you.
imageShowLegendDiv = domConstruct.create('div', {
'class': 'showLegend-div jimu-float-leading unfold',
'imageShowLegendDivId': layerInfo.id
}, layerTdNode);
RobertScheitlin__GISP
Andrew,
   OK, so there are some changes for 2.3 then. Here is the code that works for 2.3
      //bind event
      this.own(on(layerTitleTdNode,
        'click',
        lang.hitch(this,
          this._onRowTrClick,
          layerInfo,
          imageShowLegendDiv,
          layerTrNode,
          tableNode)));
      setTimeout(lang.hitch(this,
         this._onRowTrClick,
         layerInfo,
         imageShowLegendDiv,
         layerTrNode,
         tableNode,
         {}), 300);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Here is a link to a blog on how to format code in GeoNet:
/blogs/dan_patterson/2016/08/14/script-formatting
Andrew,
  This thread answers that and it still works for 2.0 through 2.3:
https://community.esri.com/thread/178526
AndrewL
Thanks Robert. If I included the if-line-of-code I got an error. There is no ending brace. However, I removed this line and it works now.
  1. if(layerInfo.newSubLayers.length > 0){
Sorry I forgot that requester was looking to expand only the first level.
Don't forget to mark the question as answered by clicking on the correct answer link.
AndrewL
I forgot to mention I had to update imageShowLegendNode to imageShowLegendDiv.
Also, while this does work, I do get 2 console errors.
Uncaught TypeError: Cannot read property 'ctrlKey' of undefined
at Object._onRowTrClick (LayerListView.js?wab_dv=2.3:406)
at init.js:62
Sorry I am confused as to how to paste source code. This does not look good below. Also there is no preview option.
//bind event
 'click',
 lang.hitch(this,
 this._onRowTrClick,
 layerInfo,
 imageShowLegendDiv,
 layerTrNode,
 tableNode)));
 this._onRowTrClick,
 layerInfo,
 imageShowLegendDiv,
 layerTrNode,
 tableNode), 100);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Andrew,
      //bind event
        'click',
        lang.hitch(this,
          this._onRowTrClick,
          layerInfo,
          imageShowLegendDiv,
          layerTrNode,
          tableNode)));
         this._onRowTrClick,
         layerInfo,
         imageShowLegendDiv,
         layerTrNode,
         tableNode,
TimHayes
The code for 2.3 works in 2.4 as well. I just tried it. Great work, Robert!
by Anonymous User
Not applicable
Great work Robert indeed! Confirmed working perfectly also on WAB 2.5!
JacksonTrappett
Robert, is there an interactive way to do this - ie. when a user checks a box for a certain layer or sublayer to turn it on, it'll expand to show the symbology, and then when they turn it off, it'll collapse? (as opposed to having the legend pre-load with them all expanded?)
Jackson,
   This is what that would look like:
    _onCkSelectNodeClick: function(layerInfo, ckSelect, evt) {
      if(evt.ctrlKey || evt.metaKey) {
        if(layerInfo.isRootLayer()) {
          this.turnAllRootLayers(ckSelect.checked);
        } else {
          this.turnAllSameLevelLayers(layerInfo, ckSelect.checked);
      } else {
        this.layerListWidget._denyLayerInfosIsVisibleChangedResponseOneTime = true;
        layerInfo.setTopLayerVisible(ckSelect.checked);
      if(ckSelect.checked){
        var imageShowLegendDiv = query("[imageShowLegendDivId = " + layerInfo.id + "]")[0];
        var layerTrNode = query("[layerTrNodeId = " + layerInfo.id + "]")[0];
        var tableNode = query("[subNodeId = " + layerInfo.id + "]")[0];
        if (domStyle.get(tableNode, 'display') === 'none') {
          this._onRowTrClick(layerInfo, imageShowLegendDiv, layerTrNode, tableNode, {});
      evt.stopPropagation();
