How do I enable image upload feature on Portal?
1409
01-31-2017 06:18 AM
WilliamDeGraw
Background information, a user is in the application configuration wizard "Welcome to the Map Tour Builder" on the step adding images. My issue is the right side labled 'I need to upload my images' is greyed out with a message of 'this feature is disabled on Portal for ArcGIS'. As an admin on Portal, where to I go to enable the feature? I've inserted an image to show the desired outcome - feature is enabled.
an example of screen where you can successfully upload my images
Thank you,
William
JayantaPoddar
Do you have publishing privileges? You must have publishing privileges to upload images from your desktop.
Think Location
WilliamDeGraw
Thank you for replying. On Portal, I reviewed the role for the user.  All publishing privileges are checked.
AdamZiegler1
Hi William,
Check out this thread. https://community.esri.com/thread/161481
-Adam Z
