Open PDF Feature Attachment to Specific Page Number
2635
01-25-2017 01:51 PM
DanAllen
In desktop ArcGIS, you can configure hyperlinks to open to a specific page in a multi-page pdf, if your attribute data has the page number.  In ArcGIS online if you have a multi-page PDF stored as a feature attachment, and your attribute table contains page numbers for each point/line/polygon in the map, can you create a way to click on the feature attachment and have it open to page 52 of 144 for example?
I have an engineering record/as-build map viewer where the extent of each sheet from a plan set is graphically drawn as a rectangle on the map.  The PDF page number is stored as an attribute, and the multi-page pdf is stored as a feature attachment.  But it is cumbersome to open a 200 page PDF attachment and scroll to page 147.  I don't have an internal web server or I could just store them as a pdf page open url.  https://helpx.adobe.com/acrobat/kb/link-html-pdf-page-acrobat.html
http://support.esri.com/technical-article/000008917
Tags (1)
jasongraham
add #page=4 after the .pdf in the URL  "4" being whatever page you need
