trying to change text with ListLayoutElements,
2312
5
01-19-2017 08:15 AM
petegillard
it only works searcing with actual string. can't find the text when i use  * . changing date and path strings, so they're not all the same.
ex.
for dA in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
     if dA.text == 'DATE: 10/10/2011':
         dA.text = 'Date: <dyn type="date" format=""/>'  THIS WORKS
for fp in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
        if fp.text == 'FILE: *':
        fp.text = 'Document Path: <dyn type="document" property="path"/>' THIS DOESN'T WORK
Thanks in advance for any ideas.
Pete
IanMurray
Honored Contributor
Maybe try the reverse logic to this.
Using the in operater you can check if a string contains a subtring, that way you don't need a wildcard
        if 'FILE: ' in fp.text:
http://stackoverflow.com/questions/3437059/does-python-have-a-string-contains-substring-method
IanMurray
Honored Contributor
petegillard
Thanks to BOTH responses. It worked beautifully!!
DarrenWiens2
... or:
if fp.text.startswith('FILE: '):
petegillard
IanMurray
Honored Contributor
Can you please mark the question as answered?
