ArcMap Multiple Legend Entries
5441
01-12-2017 12:54 PM
EvanJoyes
I'm wondering if it is possible to have multiple attributes show up in the legend? I have a layer with letter codes in one column and the written out description in another column in the attribute table. Is it possible to both both as one label in my map legend without have to manually type them in?
DarrenWiens2
If you symbolize the feature class by letter code and description (under symbology tab in layer attributes -> categories -> unique values, many fields), then the legend entry will be "letter code, description".
DarrenWiens2
EvanJoyes
Thanks, I knew it should be in symbology somewhere!
