Cascading Story Map - loading icon map
2335
01-11-2017 03:23 AM
WijmkeBrouwer
Hello!
I am building an Cascading Story Map. I have to say that it is a great new template, thanks for adding it!
But I have got one problem.
I added a map in an immersive section. This map takes a little time to load. That, in itself isn't the problem.
The problem is that the 'Loading' icon disappears after the basemap is fully loaded. At this point the other layers take another +/- 4 seconds to load and aren't visible yet.
The users will get the impression that there isn't anything special to see in the map. Probably resulting in them scrolling further down.
Is there a way to fix this or can you fix this?
OwenGeo
Esri Notable Contributor
Wijmke,
I'm glad you are enjoying the Story Map Cascade app, and thanks for taking the time to provide feedback.
We'll take a look at providing a better loading indicator for map layers in a future release. Until then you can try to reduce the time it takes your map layers to load by generalizing them (if they are complex polygons or lines) or creating tiles. You can learn more about these techniques in the ArcGIS Online help.
Owen
Owen Evans
WijmkeBrouwer
Hello Owen,
Thank you for your fast reply! Generalizing or tiling will not always be an option, e.g. in this case I use a dataset from ESRI_NL_content.
So I really look forward to a future solution. Do you maybe have another work-around or solution?
Wijmke
OwenGeo
Wijmke -- you could try revealing the layers in your map in subsequent views rather than have them all visible in the first view.  Check out this tutorial to see how to use this technique.
Owen
Owen Evans
WijmkeBrouwer
Thanks for the suggestion..
My personal favorit is the 'Hamster zombie outbreak' example John Nelson made
