Pop-Up Window Blocking Information
2498
12-25-2016 10:25 AM
JeffDavis2
Hello All,
The AGO pop-up window (via search, click event, etc...) is an issue for me.
It takes up A LOT of valuable screen space and you can't relocate the window to adequately see the selected item beneath.
Has anyone created a work-around or custom widget that alleviates this issue?
Thank you in advance.
Jeff
RobertScheitlin__GISP
Jeff,
   Sure there is the
https://community.esri.com/docs/DOC-7355
Which paces the popups into a panel.
Jeff,
   Sure there is the
JeffDavis2
Robert,
Perfect!  Thank you so much for the help.
It's exactly what I was looking for.
Jeff
