Does workgroup database have to be SQL Server?
1495
12-22-2016 05:23 AM
Jim_Gay
I'm about to setup ArcGIS Server workgroup (10.5) and was wondering if my geodatabase as to be SQL Server or can I use another one, like Post SQL?  From what I've read, it sounds like it needs to be SQL Server and that it needs to be installed on the same server as my ArcGIS Server workgroup.  I just wanted to confirm before getting started.  Thanks!
Asrujit_SenGupta
MVP Regular Contributor
Yes, SDE Workgroup will only work with SQL Server Express edition.
No, you can have a separate Database Server and ArcGIS Server. Having both on same server is not necessary.
Asrujit_SenGupta
Jim_Gay
Thanks!
