LIDAR DATA
1696
12-21-2016 02:08 AM
PaulCreaton
I'm hoping someone can help me. I have received some LAS files which I am able to bring into arcgis pro. I have generated a stats text file for the dataset in ArcGIS Pro but while it gives me info on the types of return etc, it gives no information on the point density of the las files. Is this information available? Also do I need to save it as a text file in order to view it?  I have done the same process using Arcmap and was able to get basic information on the las dataset such as point spacing simply by calculating the statistics. I have attached a copy of the stats file I generated.
Many thanks in advance
DanPatterson_Retired
equivalency in functionality has been promised in PRO 1.4, in the interim, you will have to continue to use both platforms should you not find the equivalents in pro... I assume you began your search here Geoprocessing and LAS datasets—Help | ArcGIS Desktop
PaulCreaton
OK. Many thanks for the reply.
ArthurCrawford
Hi Paul,
You can, for now, click on the Analysis Tab, click on Python window and put the following line in.
arcpy.Describe('lasdataset.lasd').pointSpacing
It should give you an output like:
0.6295601504583404
Thanks to Joseph McGlinchy  (Esri),
I'll let you know if I hear of another way,
Arthur Crawford - Esri
ArthurCrawford
Hi Paul,
You can also get the point spacing for individual LAS files within a LAS dataset in Pro 1.4 at a file level using Identify.  In Map View, zoom out such that the file extents draw, then the Identify reports:
Thanks to Clayton (Esri),
