Customize the filter popup attribute table
2230
12-21-2016 04:22 AM
GilbertoMatos
Hello!
I need to customize the filter popup screens that open through the "Filter" option of the attribute table widget. For example:
- Change the label "All" and the label "None", where it says "of the following expressions in this parameter are true";
- Remove the "Field" option.
These options are in the "Add an expression set" option.
Thanks for any help, because I could not find where to change this information.
Thank you!
Gilberto.
RobertScheitlin__GISP
Gilberto,
   The html template for the add an expression set is here:
[install dir]\server\apps\[app#]\jimu.js\dijit\templates\_FilterSet.html
<option value="AND" selected>${nls.all}</option>
<option value="OR">${nls.any}</option>
Your biggest issue is that any changes you make will affect the query widget and any of widgets that use the jimu.js\dijit\templates\_SingleFilter.html and _FilterSet.html
You can add a style attribute and set to display: none; for what ever you do not want to appear on that template.
Gilberto,
GilbertoMatos
Thank you Robert!
That's what I needed.
I'll mark you as the correct answer.
Hug,
Gilberto.
