Not able to set proxy settings in web appbuilder
2028
12-19-2016 05:06 AM
MrunalikaPanda
Currently I am using a web appbuilder application(a service which has authentication).
I am able to implement the service but unable to remove the authentication window as i already gone through the proxy settings.
Still not able to remove the authentication(as it fail to hit the proxy).
Please suggest me a way to do a proper proxy setting like "httpProxy" settings and proxy.config settings with a proper example.
Thanks in advance.
RobertScheitlin__GISP
Mrunaika,
   So you have seen and followed this link?
Setting up a proxy with Web AppBuilder Developer Edition | Support Services Blog
MrunalikaPanda
Hi Robert Scheitlin, GISP,
Thank you somuch.
I was helpful,it solved my problem.
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
