Limit size of numeric fields in widget geoprocessing with javascript mask
662
12-15-2016 07:52 AM
GilbertoMatos
Hello!
I need to limit the size of the longitude and latitude fields of a geoprocessing widget I have customized. I need to have a maximum of 6 decimal places, and only typing numbers, comma, and the hyphen character should be allowed.
I tried to use a javascript function that I developed, but I can not run it inside the widget, such as onkeypress = "myFunction ()". I always get an invalid template error message.
I've also tried using the code below, but it does not limit the amount of characters at the time of typing, ie I need to block typing the seventh decimal place.
Any tips on how I can do this?
Thank you!
Gilberto.
