Scale-based style change for a line
5224
9
12-13-2016 02:57 PM
PierreKurth
How can I change the style for a line lets say the colour changes for a road when the scale is changing in preparation for a multi-scale Vector Tile Map? Any help would be great.
Pierre
AdrianWelsh
MVP Honored Contributor
Pierre,
Check out almost at the bottom of this article:
Modify symbols—ArcGIS Pro | ArcGIS for Desktop
You can also reduce the size of symbols at smaller scales to reduce visible density when a map is viewed at smaller scales. To use scale-based sizing, check Enable scale-based sizing. A slider appears below the Size property for point symbols, the Line width property for line symbols, and the Outline width property for polygon symbols to control the size at different map scales.
Scale-based sizing is only available in maps. It is not available in scenes. To learn more about scale-based symbol sizing and authoring multiscale maps, see Author a multiscaled map
PierreKurth
Adrian,
I'd like to change the colour of a line rather than changing the width. Unfortunately Esri's help does not cover that.
JayantaPoddar
I would have created a Group layer consisting of multiple layers (of same feature class) visible at different scales and desired symbology for each layer.
Displaying layers at certain scales—Help | ArcGIS for Desktop
Think Location
PierreKurth
Jayanta,
thanks for the help. It looks like I need to do it the old way like I did in ArcMap for our raster tile layer map in the past. I thought with ArcGIS Pro there is now a more elegant way.
Pierre
JoshuaBixby
MVP Esteemed Contributor
In ArcGIS Pro there is Scale Range Symbology (see Refine the visible scale ranges for symbol classes), which I think would achieve what you want; but unfortunately, it doesn't apply to vector tile layers brought into Pro.  Vector tiles are great, but Esri's implementation and adoption are still quite immature.  I look forward to them continuing the expand both, hopefully.
KateLeroux
I've discovered a workaround for this, but it's kind of hacky:
  1. Change the symbology to Unique Values (from Single Symbol, which I assume you're using here).
  2. For the value field, choose one that has the fewest possible values.
  3. Add all the values.
  4. Select all of them, and group into a single group.
This gives you access to the 'alternate symbol' feature. First switch to scale range view (using this button: ). Then the alternate symbol button appears (). It's straightforward from there, or you can read more details on this feature under the Show different symbols at different scales heading here: Scale-based symbol classes—ArcGIS Pro | ArcGIS Desktop
Once the vector tile layer is published, you can edit the JSON style file manually to do it the right way (symbolize a single layer using scale stops for color and size). More: Update vector tile layer style—ArcGIS Online Help | ArcGIS
Arne_Gelfert
Has there been any change to this in later versions of Pro? I'm still using 2.2 and have found no better way than Kate's hack to show a feature with one symbology upto scale X and then with another symbology. Having to create classes for that seems silly.
KoryKramer
Esri Community Moderator
Scale-based symbol classes—ArcGIS Pro | Documentation still shows this as available only for unique value and graduated renderers:
I did find the following enhancement request which is "In Product Plan" but is not currently assigned to a release: [ENH-000123002: Allow users to set different symbology for the same layer at different map scales when using single symbol symbology.]  It might be good to submit this specifically on ArcGIS Ideas‌ to get a better gauge for demand (i.e. there is currently 1 customer interested in that enhancement + this thread...)
PatriceLabbé
Any news with this enhancement? We need this with unique value symbology in ArcGIS Pro and to be able to publish it to ArcGIS Enterprise. Our need is for MapServices supporting WMS services. If it is possible for label classes, it should be possible for symbols. Remember this was something done with ol'ArcIMS (SCALEDEPENDENTRENDERER ). I surely can submit on ArcGIS Ideas if necessary.
