How to slice a word in the label expression
2852
10
12-07-2016 12:23 PM
PeterVersteeg
Occasional Contributor II
Hallo,
I have a field with city names and I want to slice the name in the label expression to only the 1st character.
I want to do this in python. looking at the internet i have this but it is not working:
def Label ( [CityName] 😞
     s = [CityName]
     s1 = s[1:]
     return s1
i am working with arcgis for desktop 10.3.1
greetings Peter
FC_Basson
MVP Regular Contributor
That's weird, because I tested the expression on a layer with Null values in the attribute filed and it worked.  How about adding a None type check in there?
def FindLabel ( [CityName] ):
  try:
    if [CityName] is not None:
      return [CityName][:1]
  except AttributeError:
    pass‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoeBorgione
I got this to work:
def wtf (instring):
  s= instring[:1]   ####### Notice the position of the colon(:)
  return s
Above is in the feild calculator, in a label expression be sure to choose python as the parser and check Advanced:
PeterVersteeg
i stil got a string error
FC_Basson
It's probably due to an empty/Null attribute value, which could be returned as None.  Try this definition expression:
def FindLabel ( [CITY_CODE] ):
 try:
   return [CITY_CODE][:1]
   pass‍‍‍‍‍‍‍‍‍‍
FC_Basson
You could simplify the definition function even further:
PeterVersteeg
Your right there a NULL values and that was causing the error.  My code works if I remove the NULL values but I need same on NULL.
your code is giving me the same error.
Greetings Peter
FC_Basson
  try:
PeterVersteeg
That is weird. i now got a other error
this is my field properstie
FC_Basson
You have a left bracket in front of the CityName field in the if statement - I see I made the same error in my previous reply
PeterVersteeg
I think it was my mistake I got a extra ( in the code.
your code is working correctly. It is a more difficult code then I would think for such a simple task but I am really glad it works.
Thank you
  try:
    pass
