Uncaught TypeError: cannot read property 'geometry' of undefined
4434
5
11-28-2016 04:43 AM
Naveen_KumarKairamkonda
  I'm searching on layers using Enhanced Search widget. After I searched, Results will come in the "Results" Tab of Enhanced Search widget(screenshot: 1). When I click on the 1st resulted item, infoWindow is showing properly without any error in the console. But when I click on the other resulted items(other than the 1st resulted item i.e., 2nd, 3rd, and so on...), it's not showing the infoWindow and it's showing this error in the console. Error: Uncaught TypeError: cannot read property 'geometry' of undefined(Screeshot: 2)
Screenshot: 1 (i'm getting the infoWindow here - this is the 1st Resulted Item)
Screenshot: 2 (Not getting the infoWindow for the resulted items except the 1st resulted item)
Please suggest me, because of what I'm getting this error.
Regards,
Ibrahim.
RobertScheitlin__GISP
Ibrahim,
   What version of WAB and what version of the widget are you using because line 2822 in version 2.1 has nothing to do with geometry?
Hi Robert,
Thanks for the quick reply...
Im using WAB2.0
Ibrahim,
   And Like I asked before which version of the eSearch widget are you using? You can click on the widget holding the "Alt" key on you key board to get a dialog that tells the widget version.
Version:  1.3.0.2( i have checked in manifest.json)
Then you need to use the proper eSearch widget for the version of WAB you are using.
