WAB Dev Edition Edit widget numeric field formatting
1242
11-23-2016 07:54 AM
MichaelMiller2
There seems to be an issue with displaying numeric fields without thousands separators when viewing attributes in the editor widget. The fields have been formatted in the web map and appear correct, no thousand separator, in the standard popup. The attribute values when viewed in the edit widget include a thousand separator.
Anyone know of a way to "fix" this??
RobertScheitlin__GISP
This is the closest thread I have seen to a fix for this:
https://community.esri.com/thread/175735
MichaelMiller2
Thanks Robert!
Bummed, that solution is a rather kludgy.
