Possible to side load a map
1055
11-21-2016 10:43 AM
by Anonymous User
Not applicable
When using the "geopoint" function in Survey123 is it possible to load in your own map with points labeled, if you are in the general area using the GPS to center you?
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Peter,
It is possible to side load a map to use as a basemap, typically for offline use. I suppose the basemap could contain points with labels, but they will not work dynamically with a GPS or anything.
Prepare basemaps for offline use—Survey123 for ArcGIS | ArcGIS
Hope this helps,
by Anonymous User
Not applicable
Thanks Derek.
