[Bug Report] Survey123 Web does not pre-populate default value
1650
11-19-2016 05:59 AM
by Anonymous User
Not applicable
Surveys published via Survey123 Web do not retain the default value field.  The surveys are neither prepopulated with the default value, nor is the default value used when submitting the survey.  The data tab shows that blank entries are recorded.  I have only tested with number fields (specifically integers which are not required fields).
In fact, when creating a survey in Web, the default values don't seem to be saved at all.  When I re-open a survey to edit it further, the default values are lost.
IsmaelChivite
Esri Notable Contributor
Hi Bradley! I tried to reproduce the issue you describe without success. Just in case I am not understanding your statement, I recorded a video to shows what I experienced. If the behavior you see is different you may want to clear the browse cache and try again. If the workflow described in this video is different from what you want to do, please describe in more detail so we can reproduce.
(view in My Videos)
