Hyperlinks to to a folder in arcgis online and collector?
3669
11-17-2016 08:38 AM
GregoryMcMahon1
Is there any way of hyperlinking a folder location in arcgis online. The hyperlink will work in arcmap but when i try to select the link in gis online it does not appear as a lnk. Any way around this??
Tags (1)
KellyGerrow
Esri Alum
Hi Greg,
Where is the link to your local file located? Is it in the attribute table or are you adding it directly to a pop up?
UNC paths are not supported html in the pop ups: Supported HTML—ArcGIS Online Help | ArcGIS
-Kelly
GregoryMcMahon1
Kelly,
Its on my network or even my C/Drive. I can set up the link in the attribute table in ArcMap but when I bring it through to ArcGIS Online and the collectore app I cannot open the link. I was just wondering if there was any way around this.
Greg
CarmelConnolly
Hi Gregory,
Links will only work in ArcGIS Online if they begin with http:// or https:// - your documents would need to be sitting somewhere that has Internet Information Services (IIS) enabled/installed . It's possible to do this for your own machine but I think it would have to be kept on all the time for the links to remain active. The URL to your documents would then be something like http://machinename.com/word.doc
Carmel
