Is there a way of setting up a custom base map when designing the survey using Survey123.arcgis.com
1036
11-12-2016 07:16 AM
BrianKaplan1
I have found directions for adding urls to the .info file for surveys created using the Survey123 Connect.  Does this work for surveys created with the web survey creation tools at Survey123.arcgis.com or is there another way?
IsmaelChivite
Esri Notable Contributor
Hi Brian. Not at the moment. It is still in our backlog. You could download your survey into Connect and manipulate the basemap there... although at that moment the survey would no longer be available for data capture from the web browser (Surveys published from Connect cannot be rendered on a web browser). Thanks.
