Batch Attribute Editor: Multiple Date Fields
1176
11-09-2016 01:09 PM
JamesCrandall
Possible bug: The batch attribute editor allows you to specific multiple date-type fields in the configuration, however when attempting to perform a batch attribute update only 1 of the date-type fields shows a calendar control drop-down and you cannot manually type in the date information.
Can anyone confirm this?  Workaround?
Thanks!
Tags (1)
JamesCrandall
I think this may be a publishing issue.  I re-published the same Feature Class again as a new hosted Feature Layer and configured the widget on it and it appears to function as expected.
