web app builder url parameters changes geometry
1082
11-08-2016 05:56 PM
AlistairFox
I am passing in a building ID and zooming to the result in Web App Builder hosted on AGOL. But the result changes the geometry as you can see below. The left image is what happens when the app loads, the right image is the original. This only lasts for the session!! A Reload and the geometry is back as normal. If I run a query using the Query Widget inside WAB it zooms to the building and doesn't change the geometry.
Anyone with any bright ideas?
RobertScheitlin__GISP
Alistair,
   As this is the AGOL version you are talking about there is nothing anyone here can do. You need to call this one into esri tech support.
